20 minutes ago, xYowie said:
cpu 2 years old and i want 1 more year from it, cooling isnt a problem so how much voltage can i push thru it while being almost certain it will last 1 year?
yeah I got mine up around the 1.45-1.5 at about 4.9 easy for agessss until I got 6600k. Don't be too scared tho, but I wouldn't go over 1.5, gl
https://linustechtips.com/topic/678594-voltage-for-fx-6300/#findComment-8731480
what motherboard do you have?
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/678594-voltage-for-fx-6300/#findComment-8731554
