pcie lane problem
Go to solution Solved by incarnate,
7 minutes ago, naokuronao said:
II will try but I don't have the space which is why i was curious if there any workarounds.
There are no workarounds for things that are working as intended.
You are plugging your wifi card into a slot that is meant for sli. Pick literally any other slot and the "problem" goes away.
Having said that, I doubt that there is a performance difference anyway. Gen 3.0 8x is the same bandwidth as gen 2 16x. I doubt that it is bottlenecking the titan.
Hello, I'm using an X99A Gaming Pro Carbon motherboard from msi. I'm having an issue, when plug in my wifi expansion card into the 4th pcie slot, my graphics card on the first slot will run at x8 instead of x16. With just only my graphics card, it will be at x16 speed. My cpu is the i7-6850k which has 40 pcie lanes so there should't be problem with using another pcie slot. I could plug it at other slots but it will be too close with my graphics card and I prefer not to do that.
https://linustechtips.com/topic/678509-pcie-lane-problem/
What GPU? Although This could be an issue, I don't think any GPU out there could realistically saturate a x8 PCI-E slot so performance would be unaffected ( everyone says it will never bottleneck but I personally don't know the numbers of how much bandwidth the card uses)
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/678509-pcie-lane-problem/#findComment-8730468
Check the mobo manual for correct PCIe placement. Not saying it is in this case, but the mobo might sometimes hold a specific placement order for correct lane funtioning.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/678509-pcie-lane-problem/#findComment-8730503
I do agree with that. I'm using the overkill Titan X Pascal as my graphics card.
https://linustechtips.com/topic/678509-pcie-lane-problem/#findComment-8730682
Sorry for the late reply, I just re-read the manual. It does say that the slot I plug my wifi expansion card is an x8 slot. Other than that the manual just explains about the correct SLI configuration for my board. Would it be better plugging into a pcie 2.0 lane instead?
https://linustechtips.com/topic/678509-pcie-lane-problem/#findComment-8730729
just plug to pcie x1 slot
https://linustechtips.com/topic/678509-pcie-lane-problem/#findComment-8730739
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/678509-pcie-lane-problem/#findComment-8730798
I see, thanks for clarifying!
I don't mind too much about it running at x8 as long as it can still perform as intended, but I will try to see if I can fit it the intended pcie slot.
https://linustechtips.com/topic/678509-pcie-lane-problem/#findComment-8730813
35 minutes ago, naokuronao said:
I'm just using one but I changed the cooler on the graphics card to the accelo extreme cooler.
The cooler is a triple slot design. Easy fix. Looking at your board manual, counting from top to bottom. PCIe x16 slots 1, 2, 3 ,4. #1 and #2 runs at x16 with a 40 lane cpu, while #3 and #4 runs at x8. Remove your gpu and plug that to pcie x16 slot #2 and your wifi card to pcie x16 slot #1. There is a pci x1 slot between your wifi card and gpu.
Now your gpu will still run at x16 and still have plenty of breathing room.
https://linustechtips.com/topic/678509-pcie-lane-problem/#findComment-8731002
Thanks for the input! I was thinking about that as well. I'm just worried that because its right above the cooler and it could get pretty hot from the graphics card. But I will try and see if it will work out!
https://linustechtips.com/topic/678509-pcie-lane-problem/#findComment-8732626
You worry way too much. Your front intake fans should draw cool air over them. Still concern with them? Grab a Antec spot fan or add a side panel fan.
https://linustechtips.com/topic/678509-pcie-lane-problem/#findComment-8733440
Well, I'm still relatively new to pc building and I bought a lot of expensive hardware haha. But thank you again for your reply.
https://linustechtips.com/topic/678509-pcie-lane-problem/#findComment-8737624
15 hours ago, smokefest said:
8x or 16x dosnt change anything in performance.
My 1070 is on 8x and I get same or better fps than other people online with 16x. Most of the time i get way more fps because of my OC :)
That's awesome to hear! Yeah I hope I can get some nice oc as well with my graphics card too!
https://linustechtips.com/topic/678509-pcie-lane-problem/#findComment-8737625
