Help for compatability
Go to solution Solved by bgibbz,
Yes. I strongly recommend designing your PC on pcpartpicker.com, as it will compatibility check for you.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/678418-help-for-compatability/#findComment-8729449
Yes, but I'd recommend using pcpartpicker, also you should get an hdd as well for storing other stuff that you may have.
Im not sure if that's a good power supply or not, I'm not even sure if I can search that up and get the same result as you have.
https://linustechtips.com/topic/678418-help-for-compatability/#findComment-8729455
4 minutes ago, K44n said:
Are these components compatabil
Gtx 1060 oc strix
i5 6600k
z170x ultra gaming
panteks evolv atx
corsair led ddr4
ocz trion 480 GB
be quit 600W 80 plus gold
use pcpartpicker. please.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/678418-help-for-compatability/#findComment-8729457
