Near the center. You can partition the drive to just this part. This is called short-stroking. here is a video about it:
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/678413-hdd-speed/#findComment-8729401
Linus literally says the opposite of what you're saying. The edge moves faster than the center, meaning the head can access data faster at the edge of the platter than near the center.
https://linustechtips.com/topic/678413-hdd-speed/#findComment-8729427
Sorry, my mistake. I watched that video a long time ago, wasn't quite sure
https://linustechtips.com/topic/678413-hdd-speed/#findComment-8729435
5 minutes ago, AbdulSamad said:
how can partition the drive to just this part
By default the first block is on the outside, and the last block is on the outside.
If if you format a new drive with new partitle table and  make a 100gb partition, it will be the fastest 100gb
https://linustechtips.com/topic/678413-hdd-speed/#findComment-8729462
3 minutes ago, AbdulSamad said:
how can i make the drive on outer edge
Guy above just explained it. Disk part>clean formate the drive for maybe 25% of the drives capacity (or less depending on how much spend you want) and then this partition will be the fastest.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/678413-hdd-speed/#findComment-8729490
