hey guys,
i am pretty new to the pc building world so i would like to ask for some advice.
i am planning to do a budget build, i already have a gtx 960 which is good enough for me (as i mostly play games like overwatch etc.)
and a 450w 80 plus bronze power supply.
and my budget is around €500-€600.
i am totally clueless on what motherboard, cpu, etc. to choose.
i hope there is someone who wants to take the time to help me out a bit.
btw sorry for the english ^^
https://linustechtips.com/topic/678393-i-could-use-some-help/
3 minutes ago, Erwin Kooiman said:
hey guys,
What country do you live in? prices will vary by country
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729076
Just now, Electronics Wizardy said:
32gb ddr4
Image result for but why gif
Solitaire.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729084
1 minute ago, Electronics Wizardy said:
not much more and will speed every thing up.
Image result for that's not how that works gif
Solitaire.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729094
More than 16GB RAM for a game like overwatch is like buying a 2TB Hard drive to store 300GB of data, for twice the price of a 1TB.
Solitaire.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729102
10 minutes ago, Erwin Kooiman said:
hey guys,
http://pcpartpicker.com/list/HdjtCy 568 euros
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729111
except it uses the ram as a hdd cache, so it will speed up opening programs and writing files.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729113
1 minute ago, Heuron said:
it may convert to that many euros, but the prices in different countries vary, a $200 CPU in the US might cost $300 (equivalent) in another country
Solitaire.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729118
but an SSD will be faster anyways, and that RAM only goes so far. It's a waste of money for this level of gaming.
Solitaire.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729122
3 minutes ago, Electronics Wizardy said:
also for the hdd, 2tb hdd are almost always faster than 1tb hdds
Solitaire.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729137
look it up. There almost always faster as they have more platters or more dense platters than read more data in a given rotation.
More platters does not mean faster. It DOES mean a higher failure rate.
You'd be better off with 2x1TBs in RAID 0, that WOULD be faster
Solitaire.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729161
Yes it does, it reads from all the platters at once, so basically raid 0
I have yet to see a correlation
But much more heat, overhead, not always faster in random workloads.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729175
1 minute ago, Thread212 said:
That is not how its work...more platter and platter density doesnt always make the HDD faster.
it depends on the controller.
Even 500gb can outperform 1Tb.
Of the same type+brand, bigger is almost always faster, but a 146gb 15k will be faster than a normal 7k2 4tb hdd.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729177
Prove it, show me the read/writes of 2 identical drives of different capacity, same cache, same brand, same speed.
Solitaire.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729194
2 minutes ago, Thread212 said:
I dont think it does..
I am not expert at this.. i hope @Godlygamer23 can explain as detailed as possible.
i am more on Psu but i am not that good.
http://www.tomshardware.com/charts/hdd-charts-2013/-01-Read-Throughput-Average-h2benchw-3.16,Marque_fbrandx46,2901.html
Look there, and search for red, the bigger drives are faster.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729204
I said show me specs, not a forum.
And the bigger WD reds have bigger cache
Solitaire.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729211
http://www.seagate.com/www-content/datasheets/pdfs/desktop-hdd-8tbDS1770-9-1603US-en_US.pdf
Cache won't help with sequential read and write
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729237
Yes it will
Solitaire.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729242
How?
The exact same way that you claimed that adding RAM would make things faster.
Solitaire.
https://linustechtips.com/topic/678393-i-could-use-some-help/#findComment-8729250
