Unless you're planning on putting it on the motherboard's tracers you will be fine. After all it is CPU thermal paste, it's supposed to go on it. I don't think it's worth getting new thermal paste. That is if you already own it.
I had an account called Joegeddon active since April 20th 2015
Desktop
AMD Ryzen 5 2600 | XFX RADEON RX580 8GB XXX | 16GB 3000MHz DDR4 | Thermaltake Versa H22 | Corsair RM550x PSU | MSI AM4 B450M-A PRO Motherboard
1TB 7200RPM HDD | 500GB 7200RPM HDD | 500GB M.2 WD BLUE SSD
Laptop - Asus UX303UA
Intel i7 6500U | Intel 530 Graphics | 12GB 1600MHz DDR3 | 256GB SATA 3 SSD
https://linustechtips.com/topic/677878-thermal-paste-help/#findComment-8723780
Arctic Silver 5, though there are others that perform a smidge better for the same cost (I don't know them off the top of my head).
AS5 is also not electrically conductive enough to be worrisome, it says so on their product page:
Quote
Not Electrically Conductive:
Arctic Silver 5 was formulated to conduct heat, not electricity.
(While much safer than electrically conductive silver and copper greases, Arctic Silver 5 should be kept away from electrical traces, pins, and leads. While it is not electrically conductive, the compound is very slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.)
https://linustechtips.com/topic/677878-thermal-paste-help/#findComment-8723791
8 minutes ago, Harshil1996 said:
So Arctic Silver 5(silver) or the coolermaster maker nano(diamond)
I know Arctic silver 5 is is still good but as it has electic conductivity risks so which is better both in performance and safety?
I7 6700k here.
it should be fine either way, but the maker nano has better performances;
http://www.eteknix.com/cooler-master-mastergel-maker-nano-review/3/
also, why did you posted in GPU section if you're asking about your CPU?
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/677878-thermal-paste-help/#findComment-8723793
I've used AS5 for YEARS. It was top-notch back in the day, but newer thermal paste with new technology built-in out does it. Personally...
- Arctic MX-4
- GELID GC-Extreme
The nano-diamond particle thermal pastes (e.g. Wanted Formula 7) are 1/2 or 1°C better, but are VERY thick.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/677878-thermal-paste-help/#findComment-8723869
