I need help picking a motherboard for my computer build. I need two system fan headers. My budget is $90 USD but the cheaper the better.
My build:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (Purchased For $204.99)
Memory: Crucial Ballistix Sport LT 8GB (2 x 4GB) DDR4-2400 Memory  (Purchased For $30.00)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  (Purchased For $61.47)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (Purchased For $49.99)
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1 Gaming Video Card  (Purchased For $296.98)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case  (Purchased For $69.99)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  (Purchased For $69.99)
Operating System: Microsoft Windows 10 Home Full - USB 32/64-bit  (Purchased For $119.99)
Case Fan: Fractal Design SSR3-140-WT 56.1 CFM  140mm Fan  (Purchased For $10.98)
Other: NETGEAR AC1200 WiFi USB 2.0 Adapter - AC Dual Band  (Purchased For $14.83)
Other: Rosewill ESD Anti-Static Wrist Strap Components RTK-002, Black/Yellow (Purchased For $5.40)
Total: $934.61
Generated by PCPartPicker 2016-10-18 19:58 EDT-0400
Thanks in advance!
https://linustechtips.com/topic/677641-help-picking-a-motherboard/
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Just now, nick5530 said:
I don't factor mail-in rebates into my price, as most of the time I do not end up using them.
And? It's still sub 90$.
2 minutes ago, nick5530 said:
Sorry did not realize, but do I need to get a Z170 since my cpu is not overclockable. Could I get an H110 motherboard and save some money?
Z170 would be nice, given that you have over 2133mhz RAM (which you can OC even further to get more performance).
If you're not up to it, however, then you can pretty much just get whatever you want.
yes you could get an h110 http://pcpartpicker.com/product/jY98TW/asus-h110m-am2-micro-atx-lga1155-motherboard-h110m-am2
Would the RAM run on the H110 motherboard fine?
Yes.
What would you recommend between the Z170 and H110?
What kind of question is that... didn't I deliberately recommend a Z170 board already? :P
ASUS since you don't need overclocking capability, and ASUS always has pretty good quality boards.
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
12 minutes ago, 3DGamerOnSteam said:
If you plan on getting a K CPU later, you can get the z170, but if not, you don't need it and the asus board would do fine.
I think I am more likely to upgrade to a new chip set than buy a overclockable cpu that is capable with Z170, so I will go with the ASUS.
