It's time for Ikaros to fly away :(
I could use some help putting a value on her. Here's the PCPP:
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  ($125.88 @ OutletPC)
Thermal Compound: CRYORIG CP7 4g Thermal Paste  ($8.50 @ Newegg)
Motherboard: Asus B85M-E/CSM Micro ATX LGA1150 Motherboard  ($78.98 @ OutletPC)
Memory: Crucial 8GB (2 x 4GB) DDR3-1600 Memory  ($39.99 @ Newegg)
Storage: Seagate Momentus 750GB 2.5" 5400RPM Internal Hard Drive  ($109.79 @ Newegg)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked ACX Video Card
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($24.99 @ SuperBiiz)
Power Supply: Diablotek 350W ATX Power Supply
Optical Drive: HP DVD1265I DVD/CD Writer  ($29.38 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($84.89 @ OutletPC)
Total: $502.40
Generated by PCPartPicker 2016-10-18 19:07 EDT-0400
My thoughts:
The i3 is worth $90-100 on eBay. The mobo is worth around $60 used, the RAM is worth about $30, the HDD is worth about $45, the 750 Ti is worth $80-100 here (used GPUs go for a premium), the case is worth $20, the PSU is worth $15, the DVD burner is worth $10 and Windows is worth $30.
I might, might replace the laptop hard drive with a 250GB 3.5" WD drive worth around $20, but I think I'd have a hard time selling a light gaming machine--and the 750 Ti makes it a light gamer--with that little storage available. I'd rather hang onto the laptop drive, though.
So that puts my total at $380 on the low end. For whatever reasons, computers go at a pretty nice premium here, so I'd probably list it at $500 and see where I ended up. Is that a reasonable number, and would you guys leave the 5400 RPM laptop drive in or go with a faster (but 66% smaller) 250GB HDD?
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/677626-appraisal-help-needed/
People only care about cpu/gpu/hard drive when buying a whole system/used. I would think $425 ish would be the most people would pay for it. I would say if your doing an auction like ebay, list a little below your min price, it will the climb into your expected range. If you are doing a normal sale, just list what you want and if no one buys lower the price till someone does.
https://linustechtips.com/topic/677626-appraisal-help-needed/#findComment-8721014
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/677626-appraisal-help-needed/#findComment-8721020
2 minutes ago, aisle9 said:
What does that...have to do...with...anything?
I'm sorry, I didn't read it carefully enough :(
SPECS:
https://linustechtips.com/topic/677626-appraisal-help-needed/#findComment-8721040
