1 minute ago, dexxterlab97 said:
Please not a G1 psu. EVGA G2
Also for good 4K suggest to get another 1080 but should be playable with single card
Why PNY SSD?
Rest is fine
idk someone reccomended it to me as a decent one for the price i have a hard drive already
https://linustechtips.com/topic/677484-first-build/#findComment-8719137
1 minute ago, Unexas. said:
You just need to get a better quality PSU like the EVGA G2
Why PNY SSD?
Rest is fine
http://uk.pcpartpicker.com/list/ZqyTHN that all good?
https://linustechtips.com/topic/677484-first-build/#findComment-8719159
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  (£308.28 @ Aria PC)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  (£48.29 @ Amazon UK)
Motherboard: MSI Z170A GAMING M5 ATX LGA1151 Motherboard  (£148.69 @ BT Shop)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory  (£89.99 @ Novatech)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  (£139.99 @ Amazon UK)
Video Card: Palit GeForce GTX 1080 8GB GameRock Premium Video Card  (£617.50 @ CCL Computers)
Case: NZXT Noctis 450 ATX Mid Tower Case  (£101.99 @ Ebuyer)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£86.99 @ Novatech)
Total: £1541.72
Generated by PCPartPicker 2016-10-18 19:19 BST+0100
palit is faster and cheaper, allows you to get a Samsung evo ssd, and G2 psu for same budget
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/677484-first-build/#findComment-8719269
Total: £1541.72
ok ima look into this thx
https://linustechtips.com/topic/677484-first-build/#findComment-8719285
2 minutes ago, Muzzy2002 said:
I managed to grab mine for £589 from Aria last week, think I got lucky!
Ryzen Ram Guide
https://linustechtips.com/topic/677484-first-build/#findComment-8719289
Ryzen Ram Guide
https://linustechtips.com/topic/677484-first-build/#findComment-8719307
9 hours ago, Muzzy2002 said:
The MSI Gaming M5 is overpriced and belongs in the £120-130 range. Here's a £150 mobo that's worth the value.
Motherboard: Gigabyte GA-Z170X-Ultra Gaming ATX LGA1151 Motherboard  (£148.33 @ Aria PC)
If you're paying £90 for 16GB ram then go with the premium ones:
Memory: G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3200 Memory  (£92.99 @ Novatech)
Memory: Corsair Vengeance LED 16GB (2 x 8GB) DDR4-3200 Memory  (£94.99 @ Novatech)
Btw if you're considering that blue palit card, it'll disrupt the red/black theme you got going on.
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
https://linustechtips.com/topic/677484-first-build/#findComment-8722019
It will breeze through any game on 1440p / 1080p. As for 4k, it won't run that much at 60fps on 4k, get another 1080 ( or even a titan pascal ) if you want that. Or, a 1070SLI won't actually be that bad either.
Only other thing i'd say is for a high-end build like this, maybe change the SSD brand and if you have the budget get a 240+ AIO cooler so you can clock the 6700k higher comfertably, it'l defintley be nice to have at 4k.
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/677484-first-build/#findComment-8723794
