Hi, I just finished my first pc build yesterday and ended up with one of the fan cables sitting on top of the graphic card backboard to reach a fan header.  I was wondering if having a cable on the graphic card backboard might cause the cable to melt due to graphic card heat?  Is it okay to leave the cable where it is?
More information:
I am using the Fractal Design's define nano s and asus z170i pro-gamer motherboard.  The fan cable is noctua a-14 sleeved cable (I am particularly worried about the sleeving).
https://linustechtips.com/topic/676301-fan-cable-on-the-gpu-backboard/
you might be able to rotate the fan 90 degrees or 180 degrees so the fan wire comes out of the top so it uses more length and doesnt have to rest on the GPU. However, if it has to, as long as your GPU either has a backplate or if it doesn't, if it rests on anything but the actual back of the GPU itself then you'll be fine
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
More information:
If it's excess cable use a little trash bag twist-tie to tighten the slack.
Ryzen 5 1500X @ 3.9GHz On 1.3625V | MSI B350M Gaming Pro | 16GB G.Skill Ripjaws V DDR4 3200MHz | 3GB MSI GTX 1060 Gaming X 2063MHz Core 9408MHz Mem | EVGA G2 550W | 250GB Samsung 850 EVO | Windows 10 Home 64-bit Version 1903 (Build 18362.295) | MasterCase Pro 3
The fan orientation is already in a position where I have most cable to work with, but not enough to route it to the top.  I can't seem to get the cable off the graphic card back board.  I might be able to if I buy several extension and make a route through the top, but I would prefer not to do that if unnecessary.  There is around a 5" cable slack sitting on the gpu backboard.  Does the backboard get really hot?
