Bitfenix Neos, I'll upload mine if you want to see.
CPU: AMD Ryzen 9 5900X 12; GPU: GeForce RTX 3080 Gigabyte Vision OC V2 10GB; PSU: EVGA 750W 80+ Gold Certified; RAM: 4x32GB (w/RGB xd); SSD: 1xM.2 Samsung 980 Pro 1TB, 1xM.2 Samsung 970 Pro 1TB, 1xWD 6TB HDD; OS: 10; Monitor: 1xAorus IPS 27" (2560x1400) 1xBenq IPS 32" 4kKeyboard: Corsair K95; Mouse: Logitech G Pro X Superlight w/ Steelseries QcK mousepad.
Laptop - HP Omen 15" w/5800U, GPU 3070, 1TB M.2 WD Black, 2TB M.2 Samsung 980 Pro, 64GB RAM.
https://linustechtips.com/topic/675635-case-recommendation/#findComment-8699298
43 minutes ago, Towsif Rahman said:
Can anyone recommend me a good case which has a side transparent window and a good case fan system with a good number of extension slot under $40.
Bit Fenix Nova. And even that isn't a great case... but its about all you're gonna get on that budget.
https://linustechtips.com/topic/675635-case-recommendation/#findComment-8699445
BitFenix Neos, slightly hard to close the cable side panel of the case. Otherwise in my opinion a really nice cheap case.
Kind of thin metal but all edges are smooth you wont get cut. Also comes with 3x3.5" HDD and 3x2.5" SSD (or laptop sized HDD's) bays which you can't find on most cheap cases. (that is if you need this many).
As for price.. well it was in the $44 mark but if you say now $34 :( then I don't know if you can find it.
https://linustechtips.com/topic/675635-case-recommendation/#findComment-8699448
