Need PSU for pc
Go to solution Solved by HKZeroFive,
Stick with the M12II.
Hi guys, I was searching for a good-"cheap" , PSU
My config will be : i5-6500 , RX 460 , 8Gb ram , x5 120mm fans... x1 SSD , x1 HDD
First I was looking at   Seasonic M12II-520 EVO Edition Bronze 520W ,(is nice and fully modular) but then CM PSU calculator says that 319W is ok.
On what PSU shoud I go?
https://linustechtips.com/topic/675533-need-psu-for-pc/
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/675533-need-psu-for-pc/#findComment-8697895
i5-6500 with a 460? For purely gaming an i3-6100 and RX 470/480 would be a better option.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/675533-need-psu-for-pc/#findComment-8698026
2 hours ago, AssAss1n said:
Anything above 400w can be ok, If you don't want to upgrade I would recommend Evga 420w PSU
There's no 420W EVGA PSU and nothing under the 550W mark from EVGA is worth considering for most systems with a GPU, maybe bar OP's system which has a 460 where a 500B would be fine.
https://linustechtips.com/topic/675533-need-psu-for-pc/#findComment-8698602
5 minutes ago, aSPIRIn4 said:
This is not a pure gaming pc , i want to play only Lol, Dota2, cs:go, starcraft2 , and maybe other rts , but that`s all.
Unless you need to multitask or have more than one monitor I don't see a reason to have an i5 over a better graphics card.
https://linustechtips.com/topic/675533-need-psu-for-pc/#findComment-8699114
I`m not that kind of guy that has the money to upgrade the cpu each year , and if by some reason I decide to get a better GPU, then I will have CPU problems, and on rts games as far as i remember cpu is more important.
https://linustechtips.com/topic/675533-need-psu-for-pc/#findComment-8699365
But you will have enough to upgrade your GPU every year?
https://linustechtips.com/topic/675533-need-psu-for-pc/#findComment-8699434
