You are going to have to be more descriptive.
Was it an online game? if so check your ping when that happens and make sure you aren't having network issues.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/675412-low-frame-rate/#findComment-8696941
I was playing battlefield 1 and rainbow six ,I do not think it is ping, if it is ping it just lag not 0 frame rate
https://linustechtips.com/topic/675412-low-frame-rate/#findComment-8696946
Was thinking the same. I play Euro Truck Simulator 2 offline and my frame rate can just tank randomly when certain modded objects spawn. Like going from 60 FPS to 10.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/675412-low-frame-rate/#findComment-8696964
Try reinstalling gpu drivers, making sure nothing is overheating, and see if your cpu/ram/disk are at 100% when it happens.
https://linustechtips.com/topic/675412-low-frame-rate/#findComment-8696974
