The FX series of CPU's do NOT have onboard video, for that you need an APU. If you buy these two things then you will need a graphics card as well. e.g GTX 660ti or HD7950.
then i should just go with a 5800k and a MSI FM2-A85XA-G65 mobo then its not for me its for my gf for gameong on here 1080p monitor
https://linustechtips.com/topic/6754-jw-help/#findComment-72747
Yes if it is not for really demanding gaming.
The first step to insanity is believing in your sanity.
https://linustechtips.com/topic/6754-jw-help/#findComment-72903
yeh im just gona buy the 5800k and the msi bord and prob idk in a few months buy a 7950 or something for it
https://linustechtips.com/topic/6754-jw-help/#findComment-72911
