Hi Guys what do you think of This build?
http://pcpartpicker.com/list/hJRMFd
any sugestions? And inprovements? I wanna stick to This price
i want to add a ssd but is 32gb enough for only Windows boot up?
(my 850 EVO 280 GB is coming in a month So i wanna use a cheap ssd for not So long)
https://linustechtips.com/topic/675270-help-with-buid/
You can get windows OEM keys off kinguin for $15. 32Gb is enough for a windows boot drive.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/675270-help-with-buid/#findComment-8695254
http://pcpartpicker.com/list/RvY8Z8
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/675270-help-with-buid/#findComment-8695257
Hey many looks fine to me. Just consider getting a new SSD after a bit. You will love it. Or even trade that hard drive for one.!
https://linustechtips.com/topic/675270-help-with-buid/#findComment-8695263
Advice one: wait a month for the SSD to do the build. So you can install windows and not have to go through the trouble of moving anything over and potential OS problems.
2. Go with a 2x4GB kit of RAM. Single channel will give you RAM bottlenecks
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/675270-help-with-buid/#findComment-8695274
Kinguin is 27 in the US. Always has been
https://linustechtips.com/topic/675270-help-with-buid/#findComment-8695285
But i have only 2 ram slots And i want to upgrade real soon to 16gb
https://linustechtips.com/topic/675270-help-with-buid/#findComment-8695321
Then get 16GB now... 8GB is plenty for gaming, and light content creation, which is really all the load I would put on an i5.
https://linustechtips.com/topic/675270-help-with-buid/#findComment-8695405
don't need dual channel, it doesn't give you any 'ram bottlenecks', you'll save the slot for later and it doesn't impact gaming performance.
https://linustechtips.com/topic/675270-help-with-buid/#findComment-8696351
The Windows directory on my Windows 10 laptop is over 35GB. You should be able to get a 60GB+ ssd for around the same price as a 32GB. Or you might consider getting a small hdd, or simply go with the 2TB hdd to start.
https://linustechtips.com/topic/675270-help-with-buid/#findComment-8696922
