"The ability to destroy a planet is insignificant, next to the power of the force"
Kirito (Main Build):
CPU Intel Core i5-6600k OC'd @ 4.6 GHz Motherboard ASUS Z170-AR RAM 16GB Corsair Vengeance LPX 2400 GPU ASUS STRIX 1070 Case Phanteks Enthoo Pro Storage Samsung 850 EVO 250GB, WD Green 2TB & Travelstar 1TB PSU Corsair CS550M Cooling Corsair H110i GT Keyboard Razer Blackwidow Chroma Mouse Razer Naga Epic Chroma Sound Sennheiser HD280 Pro OS Windows 10
Asuna (My Laptop): Razer Blade Stealth
CPU Intel Core i5-7200U w/ Hyperthreading RAM 8GB Hardwired into the system GPU I N T E G R A T E D   G R A P H I C S  Storage Samsung 960 EVO m.2 120GB Cooling Fans yo Keyboard Razer Blackwidow Chroma Mouse Razer Naga Epic Chroma Sound Sennheiser HD280 Pro OS Windows 10
Yui (My mini server):
TBD
https://linustechtips.com/topic/672974-a-build-for-a-friend/
Just now, g12601 said:
No need for a Z chipset with a non overclocking CPU, other than that everything looks great.
What chipset would you recommend then?
TBD
https://linustechtips.com/topic/672974-a-build-for-a-friend/#findComment-8670926
You don't need a z170 board if you are not using a k series motherboard for overclocking
H170 or H110 what matters is the features wanted and reliability
(this is just a money saving suggestion btw)
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/672974-a-build-for-a-friend/#findComment-8670931
Hows this?
http://pcpartpicker.com/list/KHK4gL
TBD
https://linustechtips.com/topic/672974-a-build-for-a-friend/#findComment-8670950
It's better, now does it have all the things you want on it?
yis
TBD
https://linustechtips.com/topic/672974-a-build-for-a-friend/#findComment-8670958
Decent enough, and it saves 40 bucks
https://linustechtips.com/topic/672974-a-build-for-a-friend/#findComment-8670959
ayy lmao i got 40$
TBD
https://linustechtips.com/topic/672974-a-build-for-a-friend/#findComment-8670964
2 minutes ago, Topkek said:
ayy lmao i got 40$
Or you could use an older BIOS (or just not use Win10) and you could OC your non-k CPU with a Z170.
But it's your choice, really.
BTW to anyone else looking at this, yes, it still works.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/672974-a-build-for-a-friend/#findComment-8670972
