Need help setting up my digital camera as a webcam
Solved by Streetguru,
1 minute ago, BaconRace said:It has a mini hdmi connector.Any hdmi capture cards you recommend? I don't have room for a Pci-e one so can't get one.
USB might work I Guess, but, going for PCI-e is totally the way to go though....
I guess this company makes a thing specifically for that no idea on price
https://www.epiphan.com/solutions/hdmi-camera-over-skype/
Otherwise any of the Elgado HD60 stuff is probably fine so long as it can handle 1080p 60fps probably
