Hi guys, I would love to upgrade my horrible pc :( http://tinypic.com/view.php?pic=15rdwdj&s=5#.UmMO-vk7th2 I want to be able to play BF3 on low settings at 60 fps 1080p while recording at 30fps...
Should I upgrade my GPU first? If so, to what? My budget is currently 100$ for a gpu but the lower the budget can be, the better.
Take in mind that my psu is bad and has low watts, the lower the GPU wattage will be the better since I won't have to spend extra cash on a PSU. (My pc and budget are low)
https://linustechtips.com/topic/67198-what-should-i-upgrade-first/
Erm...yeh.
All of it.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
First buy an HD 7750
Next buy a Q6600
Hi there again :)
Ok thanks for answering, should I get 1 GB VRAM of GPU or 2 GB? Is this ok? http://pcpartpicker.com/part/powercolor-video-card-ax77501gbk3h Also can I run it with my PSU currently until I get a new one?
upgrade all parts!
just save some more money and build a new pc!
Erm...yeh.
All of it.
Sadly, I don't really have much money like you guys with the titans xD I can only upgrade once in a while, this is very important to me, please tell me what to upgrade first... is a 7750 good?
To be perfectly honest.
I would say wait and save up...if you buy things now, they are going to be pretty bad later down the line, specially with buying such dated parts :/
Honestly....
save your money and put away whatever you can every week or month.  Then 6 months from now you can get yourself something decent at once that will last you....
I wouldn't recommend bothering to upgrade anything.
Old Rig | Cpu - Intel Q6600 @ 3.5Ghz | Cooler - Cooler Master Hyper 212+ | Mobo - Asus Rampage Extreme | Ram - 8GB OCZ Gold 1600mhz | Gpu - 2x Asus DK Radeon HD 4870 1GB (Crossfire) | Psu - Corsair TX750W | Case - Thermaltake Element G
New Rig | Cpu - Intel 4770K @ 4.5Ghz | Cooler - Swiftech H220 | Mobo - Asus Z87 Deluxe | Ram - 16GB Kinston Hyper X Beast @ 2400Mhz | Gpu - Sapphire R9 290X | Ssd - Kingston Hyper X Beast 3K 240GB | Psu - Corsair HX850W | Case - Fractal Design Define R4
Hi there again :)
An HD 7750 will work fine with your current psu, but make sure that you get an HD 7750 with 1GB GDDR5. NOT DDR3
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
Hi there again :)
