Distance solutions?
Go to solution Solved by Jogostar,
The engines will only burn for 2sec. It will continue flying after that though.
I need a physical relay to tell me where its at
I can calculate max alt if it was to fly straight without wind or air resistance. But it wont be a true number
You could just use an Altimeter
http://www.apogeerockets.com/Electronics_Payloads/Altimeters
EDIT: This is the simplest one: http://www.apogeerockets.com/Electronics_Payloads/Electronics/Jolly_Logic_AltimeterTwo
2nd EDIT: This one is good, too. and cheaper: http://www.apogeerockets.com/Electronics_Payloads/Electronics/Jolly_Logic_AltimeterOne
Hey guys.
I'm currently studying Aeroscience Engineering and we are working on small rocket designs to evaluate team building. Our project is to build a rocket with a body length of 1m and carry a payload and retrieve it safely.
We also must calculate max altitude and i'm the IT manager. I was wondering if there is a small Arduino app or a similar device that would relay back to the base and give me a ping readout or possible distance from launch.
through simple trig i could calculate max altitude without any issues but i need to find a solution to calculate the distance from the launch pad to the rocket's apogee.
thanks guys,
John
TL;DR
Is there a small device that tells me distance from Point A to Point B with <1ms refresh time?
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/67152-distance-solutions/
What's the theoretical distance you will be achieving? You will quickly come out of range from any existing wireless signal.
this gen we should be around 1km
but our next gen should hit 1.5km
antennas should reduce this issue correct?
https://linustechtips.com/topic/67152-distance-solutions/#findComment-918527
Hey guys.
thanks guys,
John
TL;DR
You could just do the mathmatic way, for example:
If you knwo that the rocket will fly 10 m/s and it flies for 1 min
So: 10m/s x 60s= 600 meters...I think xD
EDIT: There is an awesome site, for some ''basic'' equations: http://my.execpc.com/~culp/rockets/rckt_eqn.html#Method
"Probably Because I'm A Dangerous Sociopath With A Long History Of Violence"
https://linustechtips.com/topic/67152-distance-solutions/#findComment-918549
But after a period of time, it starts to slow down...
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/67152-distance-solutions/#findComment-918570
https://linustechtips.com/topic/67152-distance-solutions/#findComment-918585
https://linustechtips.com/topic/67152-distance-solutions/#findComment-918609
ive looked at altimeters but i was trying to find a potentially cheaper solution but the simple one you posted seems to have quite a bit of features for the price.
thanks :D
https://linustechtips.com/topic/67152-distance-solutions/#findComment-918688
thanks :D
Maybe you already saw that, but I'm going to say it anyway, the USB is just for loading, you can't access data on the thing, if you have the results, you need to write it down.
Just want to let you know. :)
Quote: ''Q. Does this AltimeterOne store data that can be downloaded to a computer through the USB port?
A. No. The AltimeterOne USB connector is only to charge the battery. This altimeter does not store data other than the peak altitude, which is displayed on the LCD screen.''
https://linustechtips.com/topic/67152-distance-solutions/#findComment-918714
ya i saw that :) it should be fine though :)
thanks again!
https://linustechtips.com/topic/67152-distance-solutions/#findComment-918724
  1. Compute Some Useful Terms
    • Find the mass M of your rocket in kilograms (kg):
      M = (weight in ounces)/16/2.2
    • Find the area A of your rocket in square meters (m^2):
      A = pi*(0.5*(diameter in inches/12)*0.3048)^2 = pi*r^2
      where r is the radius in meters
    • Note that the wind resistance force = 0.5 * rho*Cd*A * v^2, where
      rho is density of air = 1.2 kg/m^3
      Cd is the drag coefficient of your rocket which is around 0.75 for a model rocket - for a really great NAR report on Cd values click here
      v is the velocity of the rocket. You don't calculate this drag force, though, since you don't know what "v" is yet. What you do need is to lump the wind resistance factors into one coefficient k:
      k = 0.5*rho*Cd*A = 0.5*1.2*0.75*A
    • Find the impulse I and thrust T (big T) of the engine for your rocket from the engine designator, for an explanation you can reference NAR's Rocket Motor Coding, the NAR Model Rocket Safety Page, which gives the nominal impulse for each category, and the Model Rocket Motor Dimension WWW Page which gives you the actual rating for specific motors.
    • Compute the burn time t (little t) for the engine by dividing impulse I by thrust T:
      t = I / T
    • Note also - the gravitational force is equal to M*g, or the mass of the rocket times the acceleration of gravity (g). The value of g is a constant, equal to 9.8 meters/sec/sec. This force is the same as the weight of the rocket in newtons, and the term M*g shows up in the following equations a lot.
  2. Compute a Couple of My Terms (to simplify the upcoming equations). In the absence of something more colorful I call them "q" and "x"
    • q = sqrt([T - M*g] / k)
    • x = 2*k*q / M
  3. You Are Ready to Go: Calculate velocity at burnout (max velocity, v), boost phase distance yb, and coast phase distance yc (you will sum these last two for total altitude). Note that "g" is acceleration of gravity in metric units = 9.8.
    If you're not familiar with the term "exp" in these equations click RIGHT HERE.
    • v = q*[1-exp(-x*t)] / [1+exp(-x*t)]
    • yb = [-M / (2*k)]*ln([T - M*g - k*v^2] / [T - M*g])
    • yc = [+M / (2*k)]*ln([M*g + k*v^2] / [M*g])
  4. AND THE TOTAL ALTITUDE IS... yb + yc
source
https://linustechtips.com/topic/67152-distance-solutions/#findComment-918727
*snip*
we always use those equations prior to launch and that gives us a synthetic benchmark but unfortunately we experience wind or even an offset launch or potential engine failure so equations are great for hypotheticals but i'm looking for realworld readouts
https://linustechtips.com/topic/67152-distance-solutions/#findComment-918745
Well I could give you some Physics equations on how to figure it out, but how complicated it gets depends on how much information you already have on the rocket, and how specific you want the answer...
EDIT: I see that @prolemur already gave a decent explanation on some of the idea, and my vague comment is useless xP
"Her tsundere ratio is 8:2. So don't think you could see her dere side so easily."
Planing to make you debut here on the forums? Read Me First!
unofficial LTT Anime Club Heaven Society
https://linustechtips.com/topic/67152-distance-solutions/#findComment-918782
