Hey I'm wanting to overclock my CPU. It's an i7-4790k at 4.00Ghz and I have no idea where to start.
Specs are in my signature.
Basically;
How do I do it?
Any suggestions on where to start?
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/670217-how-to-overclock-a-cpu/
https://linustechtips.com/topic/670217-how-to-overclock-a-cpu/#findComment-8641785
11 minutes ago, Enderman said:
actually no...
Use this guide,  http://www.overclock.net/t/1411077/haswell-overclocking-guide-with-statistics so you wont screw up your cpu by following the overclocking.net guides, they are better and safer way to go if this is your first time.
Edited by xephoneration
grammar
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/670217-how-to-overclock-a-cpu/#findComment-8641803
1 minute ago, xephoneration said:
you will not screw up your cpu
Uh...............what the heck are you talking about?
Did you even watch the video?
Linus overclocks perfectly fine, you can't "screw up your CPU" by following an overclocking guide that linus made.
https://linustechtips.com/topic/670217-how-to-overclock-a-cpu/#findComment-8641810
I meant so you cant, typed really fast... Linus guides are good, though overclocking.net is much much better, giving the fact they do take community benchmarking, and overclocking information from the said generation. It is a much through guide and will give you better results than linus. Linus is really just going into the 101, which is not bad, but when I OC the first time I would of really prefer a better understanding on what I am doing and what others have done.
https://linustechtips.com/topic/670217-how-to-overclock-a-cpu/#findComment-8641826
Can't go wrong with OCN tbh.
https://linustechtips.com/topic/670217-how-to-overclock-a-cpu/#findComment-8641934
