They have different front panels. That is all.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
Front panels are a bit different,  plus a few minor changes.  Overall spec 03 is the superior case.
But as someone who owns one,  i would not recommend it
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
17 hours ago, RGT said:
why not?.
Cable management options are poor,  the overall layout isn't very good either.  Ventilation is ok. Cooler size is very restricted  ( it's  actually pretty narrow  and doesn't allow for an aio without modification).
Overall,  if you want a case in that budget i would suggest the  corsair r200/300 or the s340.
One nice thing however is that gpu length isn't a problem ( my 12.5 inch r9 290x plenty of room to spare,  and it accepts up to 16 inches if i remember correctly)
