Raid 0 Speed
SlowMixit
Leaving this here. This must be bug, HD Tune gave me this result 5mins ago.
I dont have RAM drive so it cannot be reading from ram, also its reading size wrong as its supposed to be 2x2Tb Drives in Raid 0.
Could it be reading from drive's cache?
"Game" : Work in Progress
"Work" : Threadripper 3970X | Gigabyte TRX40 Designare | 128GB G.Skill Trident Z Neo 3600 CL16 | Gigabyte RTX 2080 Ti Xtreme Waterforce WB | Custom Loop | Intel X520-T2 Dual 10GbE NIC
Dell R710 NAS : 2 x X5660 Xeon | 96GB DDR3 ECC | Intel X520-T2 Dual 10GbE NIC | 6 x 16TB Seagate Exos X16 | Dual 1TB Kingston NVMe as Cache | IBM M1015 flashed IT-mode | Proxmox
HP ML350P : 2 x Xeon E5 4650 | 128Gb DDR3 ECC | Intel X520-T2 Dual 10GbE NIC | Quadro K6000 | 8 x Samsung SM1625 800Gb SSD | 240Gb Intel D3-S4610 Boot | Dual 1TB Samsung 970 Pro | IBM M1015 flashed IT-mode | Dual 750W PSU
Clearly a bug. There is no way a HDD or two can push those speeds.
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
I have suspicion that its reading from RAM. As only that can explain how fast the readings are, i do have Windows 10 caching enabled so that could be the issue.
This is what i get when reading from Windows system M.2 drive, clearly normal readings for M.2 SATA SSD.
2 x 2Tb HDDs in RAID-0 would yield ~4Tb of space, not 2199GB.
Something is wonky with your setup and/or the benchmark program.
