I'm planning on getting this case for my upcoming build and the seller says it comes with 3 blue LED fans which in the picture look beautiful on the front. But the thing is,  that leaves it without any fans for the rear unless I get one,  but they're quite costly.  So,  what I plan to do is move one of the fans to the back and leave 2 at the front. Will it look ugly and how should I arrange them to look as good as possible?
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
https://linustechtips.com/topic/669353-will-my-case-look-ugly/
You shouldn't need a fan at the rear honestly. Three fans if they're any good will give your components enough airflow.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/669353-will-my-case-look-ugly/#findComment-8633701
So,  the air that gets s
ucked in from the front will try and squeeze and force their way out?
My Daily Driver:
https://linustechtips.com/topic/669353-will-my-case-look-ugly/#findComment-8633704
The case looks ugly already, but put the middle fan at the back. It will look the least ugliest. It will also be equal.
My PC Currently Is The P2-1320a.
https://linustechtips.com/topic/669353-will-my-case-look-ugly/#findComment-8633705
Just now, Freezanator said:
So,  the air that gets ducked in from the front will try and squeeze and force their way out?
Basically.
I think that's actually a good looking case personally. Doesn't look terribly well built. but it's got SSD trays and cable management holes. And a PSU shroud. There's a lot to like here.
Computer Specs:
https://linustechtips.com/topic/669353-will-my-case-look-ugly/#findComment-8633709
How is it ugly m8?
My Daily Driver:
https://linustechtips.com/topic/669353-will-my-case-look-ugly/#findComment-8633711
How is it ugly m8?
Eh, opinions.
Computer Specs:
https://linustechtips.com/topic/669353-will-my-case-look-ugly/#findComment-8633714
Case review. if a bit short, it's what we have to work with.
Computer Specs:
https://linustechtips.com/topic/669353-will-my-case-look-ugly/#findComment-8633719
Yeeeeeeeah that's not a good review
Computer Specs:
https://linustechtips.com/topic/669353-will-my-case-look-ugly/#findComment-8633724
Well it's the best out there for this case
My Daily Driver:
https://linustechtips.com/topic/669353-will-my-case-look-ugly/#findComment-8633729
Yeah you will be fine without a rear fan.
https://linustechtips.com/topic/669353-will-my-case-look-ugly/#findComment-8633739
