I have a 760t
A 970 HOF Blower Card (afaik) with three fans
An H110 Push-Pull in the front of the case
One exhaust fan
Obviously just slapped together as my first build, how could I improve temperatures here? More fans, and if so where? Less fans, and if so, which ones need to go?
Shipping sucks
https://linustechtips.com/topic/669083-advice-on-cooling/
4 minutes ago, GSTARR said:
I have a 760t
One exhaust fan
I would suggest looking at these videos
https://linustechtips.com/topic/669083-advice-on-cooling/#findComment-8630770
What you have seems fine to me.
What are your load temps?
https://linustechtips.com/topic/669083-advice-on-cooling/#findComment-8631944
Oh I'm not exactly sure my PC is all the way across the country; but when I go back this summer to Texas where ambient temperature is enough that you can sweat inside, and I want to start video editing, overclocking, painting etc. I'd like to to be somewhat cool.
My temps should be fine like you said, I used it for a good 8 months before I left and the last two months I had a stable OC of 4.1 just with the automatic tuner; however, I really just want to start learning how to "optimize" my pc. Get the most cooling w/o investing in a real loop, how to OC efficiently with the cooling etc.
Shipping sucks
https://linustechtips.com/topic/669083-advice-on-cooling/#findComment-8632196
Well, you might as well leave any tuning for when you get back to your pc.
https://linustechtips.com/topic/669083-advice-on-cooling/#findComment-8632352
well, after a point you're going to get diminishing returns and the only reason to get more/better fans would be cut down on noise. I would say you are pretty close to that point as a rad should be enough and you should have airflow for the caps and what not. the ambient temp of your room will have a greater effect than more fans so, the best course would be to leave the heavy stuff to night when heat is less on an issue.
https://linustechtips.com/topic/669083-advice-on-cooling/#findComment-8633369
Sorry for nitpicking. Blower and 3 fans can't be. Its either one. Blower is single intake with rear exhausting, 3 fans are all intakes and exhaust to all sides. Talking about GPU.
The airflow setup seems fine. Check temps when you have chance and we'll know if there's anything to adjust.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/669083-advice-on-cooling/#findComment-8634635
