Mini case
Go to solution Solved by AlvinPacheco,
Based on your build, you can try the Cougar Spike Mini Tower Gaming Case. It has good functionality for a decent gaming rig. 1 fan slot at the front, 2 at the side, and one at the back. Also if you're into modding you can easily replace the side panel to a windowed one
Just now, Frosty! said:
Hi
does someone has a good mini case where This build fits in?
http://pcpartpicker.com/list/9ZDVFd
maybe also Some more ventilators?
Linus has like 4 or 5 videos with small case reviews... (can someone find them and post them :3)
https://linustechtips.com/topic/668950-mini-case/#findComment-8629362
You have options like the Antec P50, BitFenix Prodigy M, Fractal Design Arc Mini and Phanteks Enthoo EVOLV.
You can't have a truly mini case because of the mATX motherboard. You'd need to switch to an mITX board for the tiny cube type cases.
https://linustechtips.com/topic/668950-mini-case/#findComment-8629383
If you do go for itx build don't get the silverstone rvz02, I have it and it's build quality is not what I expected. I would go with the node 202 next time.
Azure Fists - "Grown men playing with each other since 2009"
CPU : Intel® Core™ i5-4590T, OS : Windows 10 64bit + Custom Alienware Console Interface, GPU : NVIDIA® GeForce® GTX 860M 2GB GDDR5, RAM : 8GB Dual Channel DDR3L 1600MHz, SSD : Kingston V300 240GB, WIFI : Intel® Dual Band Wireless-AC 7265 2x2 + Bluetooth 4.0, CASE : Alienware Alpha, PSU : External Power Brick, MOBO : Custom Dell Motherboard.
CPU : i5 6600, Mobo : Asus Z97i-Plus, RAM : 16GB DDR4 3000mhz Corsair Vengeance LED, GPU : Gigabyte G1 GTX 1080, Case : Silverstone RVZ02, Storage : SanDisk 1TB M.2, PSU : Silverstone Strider SST-SX700-LG, Display(s) : AOC Q2963PM 29" IPS Ultra Wide 21:9, Fans : Noctua NH-L9i with Be Quiet Pure Wings 2, Keyboard : Razer Blackwidow Stealth 2015, Mouse : Razer Naga 2015, Sound : LG Wireless Soundbar /Razer Kraken Pro, OS : Windows 10
https://linustechtips.com/topic/668950-mini-case/#findComment-8629452
So the first 1s you mentiocened as cases it wil fit wit the ATX
https://linustechtips.com/topic/668950-mini-case/#findComment-8629455
26 minutes ago, Nexro said:
Would you be able to live with an ITX motherboard? Because you can't really go that small without.
Which itx Should i take
https://linustechtips.com/topic/668950-mini-case/#findComment-8629475
Adobo, Kilawin, Liempo and More. :)
https://linustechtips.com/topic/668950-mini-case/#findComment-8629486
With the atx build?
https://linustechtips.com/topic/668950-mini-case/#findComment-8629543
1 minute ago, AlvinPacheco said:
With a Micro-ATX build. The one you provide in the PCPartpicker link you gave.
https://www.amazon.com/gp/aw/d/B00DWCCS6M/ref=mp_s_a_1_1?ie=UTF8&qid=1475228926&sr=8-1&pi=SY200_QL40&keywords=cougar+spike+microatx+mini+tower+case&dpPl=1&dpID=41PQxDsRCIL&ref=plSrch
This 1?
https://linustechtips.com/topic/668950-mini-case/#findComment-8629558
3 minutes ago, Frosty! said:
Yes. or if Tecware is available in your country, try looking for the Tecware Raiden Elite or Tecware F3
https://linustechtips.com/topic/668950-mini-case/#findComment-8629572
U also know 1 a little cheaper
https://linustechtips.com/topic/668950-mini-case/#findComment-8629601
4 minutes ago, Frosty! said:
The tecware is not avaible in the netherlands
you sure everything wil fit in the cougar even my huge videocard
Yep it can fit your video card in there. Gigabyte 1060 has a length of 223mm. While the Cougar Spike supports up to 330mm
https://linustechtips.com/topic/668950-mini-case/#findComment-8629604
