linux shell script nwipe mass launcher
hello =)
got this little project im working on here started a part time job at this e waste recycling place and they throw away like 1000's of hdd because they can't wipe them at the rate they get them in so it makes me sick to my stomach
sooo iv been trying to come up with a way to stop it looked into a bunch of ways to do it anyway ended up with a copy of parted magic (linux distro obv) lol anyway the software its running is nwipe(more or less dariks boot and nuke)
i got it running today opened 2 copys (had to be ran at the same time before starting them otherwise you couldn't start all of the drives) so im working on a way to open multi tab windows running nwipe
and here is what i came up with(mind you i never tried to wright one of these before)
#!/bin/sh
WINDOW_NAME="ROXTerm"
PROFILE_NAME=Default
roxterm --profile=$PROFILE_NAME --title=$WINDOW_NAME -n 1 --tab
roxterm --profile=$PROFILE_NAME --title=$WINDOW_NAME -n 2 --tab
roxterm --profile=$PROFILE_NAME --title=$WINDOW_NAME -n 3 --tab
roxterm --profile=$PROFILE_NAME --title=$WINDOW_NAME -n 4 --tab
roxterm --profile=$PROFILE_NAME --title=$WINDOW_NAME -n 5 --tab
roxterm --profile=$PROFILE_NAME --title=$WINDOW_NAME -n 6 --tab
enter
exit
enter
i have been testing it with something like this but it fails to load nwipe in each time im guessing theirs something i need to switch to the next tab to be able to right per tab but i
really dont know lol never tried to wright one of these before
#!/bin/sh
/usr/din/nwipe
enter
/usr/din/nwipe
enter
/usr/din/nwipe
enter
/usr/din/nwipe
enter
/usr/din/nwipe
enter
/usr/din/nwipe
enter
exit
enter
ty for any help you could give =)
https://linustechtips.com/topic/668882-linux-shell-script-nwipe-mass-launcher/
your right it dose the problem however is when a drive fails finding which one failed isn't possible doesn't show which one failed just that there was a fail
thats why were splitting them up atm
the ideal is to stop them from being destroyed lol so shattering the disk wouldn't work lol
Given that you're running what is basically the same thing many times, you could use a loop instead of writing out every command individually.
for ((i = 1; i <= maxIterations; i++))
do
your thing
done
i starts at 1, goes up in steps of 1 per time around the loop, and it will stop when i gets to the maxIterations.
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
