How can I plug in multiple fans to one power connector?
EricSartor
https://pcpartpicker.com/user/ericsartor/saved/#view=CMhP6h
So I literally JUST finished building my new PC in the Thermaltake Core Mini ITX case.  I bought a couple extra fans for my rear panel, and they're installed, but I noticed there are only two fan power headers on my motherboard (one "CPU" and one "System").  The case itself only comes with one 200mm fan in the front, so I've got that hooked up to the System power header, but there's nowhere to plug in my other two fans (as far as I can tell) and my PSU didn't come with any sort of daisy chain cable, and there definitely isn't one in the case either. I tried searching "pc fan daisy chain cable" on Amazon but came up with nothing.  What solution can I use for this?  I was sure all I needed was a daisy chain cable, but maybe I'm just not searching the right thing, I don't know what those cables are actually called...
http://www.newegg.com/Product/Product.aspx?Item=N82E16812423164&cm_re=fan_splitter-_-12-423-164-_-Product
this cable allows you to power 3 fans off of a molex and still control them by the motherboard
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
A little bit of basic soldering will do the trick.
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
Just now, lopj245 said:
Orrrr just get a PWM split lol. Don't listen to that guy who wants you to solder shit.
It makes the project more interesting IMO and in some cases can be cheaper!
Main System Specs:
Laptop Specs:
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Dell 2003 Mouse
Orrrr just get a PWM splitter lol. Don't listen to that guy who wants you to solder shit.
Just goes to show how little I actually know about PC parts :P I put together this PC mostly by guessing, and I made so many mistakes...it took me 4 hours xD
Hell yes it does but if you aren't experienced then you will fuck up your board.
please tell me you removed the plastic from the bottom of the CPU cooler :P
Main System Specs:
Laptop Specs:
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Dell 2003 Mouse
Doesn't matter how long it takes as long as the job gets done properly. Glad to have you in the community!
You get to learn a new skill but I understand that some people may not feel comfortable working with stuff like that :)
Main System Specs:
Laptop Specs:
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Dell 2003 Mouse
I highly recommend going to the thrift store and buying a $10 Pentium III junker for one's first soldering project ;)
Aerocool DS are the best fans you've never tried.
Or if you are daring you could go X99.
Main System Specs:
Laptop Specs:
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Dell 2003 Mouse
If I ever find a $10 X99 system, I'm taking it as a sign that I was meant to be a YouTube sensation xD
What's a CPU cooler?
lol
Main System Specs:
Laptop Specs:
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Dell 2003 Mouse
13 minutes ago, lopj245 said:
Is it cool to put a splitter into a splitter?  cause I need three power inputs and I'm mainly seeing Y cables that only split into 2...
I personally wouldn't connect 2 splitters into each other off one header as it might max out its current rating.
Main System Specs:
Laptop Specs:
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Dell 2003 Mouse
Ah, dang, all the reputable ones on Amazon are only 1 to 2 splitters...guess I'll just buy a random 1 to 3 :P
http://www.swiftech.com/8-WayPWMsplitter.aspx
Main System Specs:
Laptop Specs:
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Dell 2003 Mouse
