So, I have a lg ultra wide (don't remember the exact number, they are all so similar :P ) and was looking at getting a couple 22-24" monitors to go along side my main monitor. So my question is is that possible (FOR GAMING, ik it will just as a desktop for productivity)? I use amd gpus simply because my monitor is freesync. I heard you can use mixed resolution in amd settings, but will games pick it up? I know games like bf4 prob will, because they tend to almost adapt to the resolution thru windows or something.
https://linustechtips.com/topic/668557-mixed-resolution-surround/
You can use it for productivity but not for gaming as the screens will be skewed to make up for the resolution difference. I would rely on Windows display settings rather than Eyefinity.
8 minutes ago, Aytex said:
Yes its possible, but and eyefinity is cancer, So is Nvidia's surround but they both suck and have problems xd, but in terms of usability yes, its possible and should work
I don't know about Eyefinity but Surround is pretty good. Most users aren't taking their time learning the intricacies of the setup process.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
  • 1 month later...
