How do you define "as fast as before" what are you using to measure the difference, what was "fast" in the before and what is "not fast" now?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/668519-please-help-me/#findComment-8624425
Just now, Techniche said:
i used to get 90 fps max settings on rust 1080p now i get 50 average
And did you power on the computer while the card was removed? Have you double checked all of the settings to make sure nothing changed or was bumped? Just want to make sure.
Prior Build Log/PC:
https://linustechtips.com/topic/668519-please-help-me/#findComment-8624439
7 minutes ago, Techniche said:
no everthing is the same as before, i just took out my gpu because the dvi port was covered with plastic still
You know you can remove that without removing your whole gpu?
Magical Pineapples
https://linustechtips.com/topic/668519-please-help-me/#findComment-8624447
