How to turn PWM fans off - Asrock H170
Hello forum !!! ^_^
    I have build a new system and put 4 pwm raijintek fans in there to get a good airflow!
My problem is that is seems there is no real control over the chassis fans, i have installed them of course on the pwm motherboard headers,
and i tried from the uefi bios to make a nice curve with them being idle at start and start spinning after cpu reaches 60C  but that wont happen
fans spin all the time and their speed from HWmonitor :
Fan 1 boreas 140m pc idle speed (should be 0)  390 rpm, rpm range from Raijintek webstite 600~1000 R.P.M. [PWM controlled]
Fan 2 Aeolus 140m pc idle speed (should be 0)  770 rpm, rpm range from Raijintek webstite 650~1400 R.P.M. [PWM controlled]
Fan 3 Aeulos 120m pc idle speed (should be 0)  390 rpm, rpm range from Raijintek webstite 400~1400 R.P.M. [PWM controlled]
Fan 4 boreas 140m pc idle speed (should be 0)  500 rpm, rpm range from Raijintek webstite 600~1000 R.P.M. [PWM controlled]
Also cpu fan is a Boreas 140m , which also spins constantly, starting at  470 rpm, besides having him start only when cpu is above 60c (like a gpu)
     Cpu temps are really low sitting at 30-40 degrees at idle and 60C under prime stress test! that's when all the fans are spinning at the rpm range shown above.
I've tried 3 methods to work this out,
- first making fan curves at uefi bios Fantastic setup, didnt not work at all.... all fans are spinning
- second i tried the F-stream tuning utility , which is like uefi bios , but on windows... and did absolutely nothing at all..
- third option was speedfan which i know how to setup from previous pc , but somehow wasnt supported by the asrock h170 perfomance fatal1ty hyper motherboard that i've got. Speedfan could not give me acces to pwm headers and didnt have that option "software controlled" neither the "manual" option worked since even when i was  tuning fans to 0% spin , nothing would change , except! the gpu fans... :/  which i already control through gpu software...
   I dont want to use an external pwm controller, since i want the fans to speed up automatically when temperature is rising! having the fans stop at idle whould make the pc so much quieter, basically silent!  , gpu and psu have that mode and at idle their fans dont turn at all, but all the pwm headers of the motherboard make my fans spin all the time ! making the pc non silent , i wish there is another way to control fans and make them stop! since my cpu G3900 can be passively cooled at idle with the enormously huge Raijintek Tisis cooler....
Hope you have some ideas so i can try to make fans turn off!!! thanks for reading !!!
Fans usually have lower bounds on the rpm limits so they can't be turned off all the way otherwise systems would overheat.
 If you want your pc to be silient, try taking some of the fans out, especially if you are not overclocking.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
well i am overclocking and i want my pc to stay cool , but at the same time i want some silence, so it would be perfect for my fan not to spin when pc is idle,,,
i have seen from other pcs that you can turn fans off using speedfan, but it wont happen to my fans .... :( if i knew that before buying my motherboard, i would probably would have bought better fans with lower rpm values....  but now my only option is to find some kind of trick to make them stop or live with that small but noticable noise!
In BIOS, go into your fan control, and select manual fan control. From there you can turn off the fans, on my Asus motherboard there is a little box that reads "Fans off" and set them to turn on at certain speeds.
If that doesn't work, you might need to use DC power instead of PWM.
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
sadly asrock's bios has not option (like your asus) to turn off fans, neither has any special manual controls, the only option is the fantastic tuning , which let you choose one of 3 presets or you can make a custom curve , which i made and set the fans to start spinning after 60c (of cpu), what i get is fans at low rpm from the start (when cpu is 30c )
so basically i guess  there is a fail safe from asrock so nobody can accidentally turn the fans off and actually damage the hardware, and i am looking a way to overcome that issue.
