Need help (SOLVED)
Solved by Garett1,
Go to the top right hand corner and click your profile name, click account settings in the drop down menu and then on the left hand side click Signature.
Then you can write whatever you want! ![]()
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
