not all the 8 pins match with the mother board connector
someone told me that rounded pins can go to square holes.  is that right?
and send me this   http://prntscr.com/cn5rzc   is it right to install the rounded pins into the square holes?
and if it fit should this be the right way?
PSU: seasonic m12ii 620 evo
MB:  asus b150 pro gaming aura
https://linustechtips.com/topic/667804-connect-44-cpu-cable-help/
Yes that is correct.
Yes, that's fine. They are keyed so that you shouldn't be able to plug in the wrong connectors.
the 4 pin in the left side is keyed some rounded and some square
but the right side all rounded and the MB right side has 2 square
Yes and that is the correct way, there is only one way to plug it in.
