Help with GTX 1080 vs Korean Monitors
Hecknologist
Hi guys,
I have upgraded my graphics card and the new one only has one DVI port. I have 2 korean 1440p monitors that only take dual link dvi. I have tried:
passive adapters,
a secondary graphics card (GTX 1080 and GT 210 are not supported on a single driver),
an active adapter from display port (was met with lines across my screen),
What can I do to get another full dual-link DVI connection from my PC with spending too much money?
Have you tried HDMI to DVI?  I use one for my PB278Q secondary 1440p monitor.
Yea, unfortunately it will not accept conversion from HDMI due to it only utilizing one link of the dual-link I require. I did look at possibly grabbing a graphics card that uses a gtx 1080 compatible driver, but they are a litle pricey over here in New Zealand.
That, or try to enable a function that the second monitor is powered by the gpu but through the motherboard ports. I did that and it works fine on my 2 monitors (1024*1280)
I5 4440//8gb Corsair Vengeance ddr3//Sapphire Radeon r9 380 4gb//ASUS h81m-plus//WD caviar blue 1tb//Cooler Master N200//Cooler Master G500
Huh, mine works fine with my 1440p monitor, weird lol
My motherboard does support Lucid MVP (or something like that) which allows for teaming of onboard and discrete GPUs. Might look into that and see where I get to.
From looking online, it seems to be because the monitors don't have scalers in them. I believe this was done to allow for better overclocking of the refresh rate. I'll have a look at a second hand PB278Q to replace the Catleap Q270, It might be time to upgrade.
