Build help!!!
Go to solution Solved by Energycore,
I have $225 and i need a case,gpu,storage and wifi card please help
https://linustechtips.com/topic/667308-build-help/
1 hour ago, asapansh said:
what are your current components
q8300 10gbddr2 evga 500b oem mobo
https://linustechtips.com/topic/667308-build-help/#findComment-8612163
Well the Corsair Carbide Spec M2 is $55.00, it's decent but being a case in that price range they did cut corners on quality. Most of your budget should go into the GPU at this point but you need to specify what games it's for. As for the rest, a 1TB WD Blue HDD like wrathoftheturkey said & I don't know jack about wifi cards. Try browsing Newegg, filtering your price & sorting by best reviews or highest rating.
Ryzen 5 1500X @ 3.9GHz On 1.3625V | MSI B350M Gaming Pro | 16GB G.Skill Ripjaws V DDR4 3200MHz | 3GB MSI GTX 1060 Gaming X 2063MHz Core 9408MHz Mem | EVGA G2 550W | 250GB Samsung 850 EVO | Windows 10 Home 64-bit Version 1903 (Build 18362.295) | MasterCase Pro 3
https://linustechtips.com/topic/667308-build-help/#findComment-8612170
Storage: AMD Radeon R3 240GB 2.5" Solid State Drive  ($59.99 @ NCIX US)
Video Card: PowerColor Radeon RX 460 2GB Red Dragon Video Card  ($104.98 @ Newegg)
Case: Fractal Design Core 2300 ATX Mid Tower Case  ($39.99 @ SuperBiiz)
Wireless Network Adapter: Rosewill RNX-N250PCe PCI-Express x1 802.11b/g/n Wi-Fi Adapter  ($16.99 @ Newegg)
Total: $221.95
Generated by PCPartPicker 2016-09-26 22:32 EDT-0400
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/667308-build-help/#findComment-8612173
Total: $221.95
Did you put an AMD like I said
https://linustechtips.com/topic/667308-build-help/#findComment-8612210
I did.
I think of you
Computer Specs:
https://linustechtips.com/topic/667308-build-help/#findComment-8612254
Just now, dexxterlab97 said:
If you did you should know I like blue more than ever and AMD is red
http://pcpartpicker.com/product/rrvZxr/crucial-mx300-275gb-25-solid-state-drive-ct275mx300ssd1
Computer Specs:
https://linustechtips.com/topic/667308-build-help/#findComment-8612267
3 minutes ago, masterkickass7 said:
If you're gonna do $40 for an SSD, do a 120GB one and you're good.
https://pcpartpicker.com/product/qf98TW/a-data-internal-hard-drive-asp550ss3120gmc
And a better CPU cooler since the one you have there isn't much better than stock.
https://pcpartpicker.com/product/FyMFf7/arctic-cooling-cpu-cooler-acfz11lp
I realize that this is already over budget, but I would drop the RX 460 to a cheaper one,
https://pcpartpicker.com/product/C6DzK8/powercolor-radeon-rx-460-4gb-red-dragon-video-card-axrx-460-4gbd5-dhv2oc
Computer Specs:
https://linustechtips.com/topic/667308-build-help/#findComment-8612384
the stock one is broken my max is $224.24 anything over is a no go
https://linustechtips.com/topic/667308-build-help/#findComment-8612395
Take this RX 460 then.
http://pcpartpicker.com/product/sXkwrH/powercolor-radeon-rx-460-2gb-red-dragon-video-card-axrx-460-2gbd5-dhoc
Computer Specs:
https://linustechtips.com/topic/667308-build-help/#findComment-8612479
Computer Specs:
https://linustechtips.com/topic/667308-build-help/#findComment-8612506
https://linustechtips.com/topic/667308-build-help/#findComment-8612541
