Need help with Corsair HD RGB fans for H100i v2 and 460x
Solved by WoodenMarker,
Just now, Florin050 said:Thanks for the help, but i don't think the SP120 fans are half as pretty as the HD120 are. I would just love to have only the HD120 fans in there...
I want the build to be pretty silent, so will the HD120 fans on a H100I still keep my processor from getting baked?
Performance wouldn't be an issue with most fans. HD120's would be fine. I'm not sure how quiet they are since I still need to look up more reviews and get some to play around with but some reviewers seem to think they're pretty quiet.
