34 minutes ago, wasiq614 said:
does anyone know how to put on cable combs like THESE?
For those kinds you put them in before assembling the sleeved cables, for pre-sleeved cables you will need to take off each wire and individually thread them through before reinstalling it correctly.
is there any video that shows how to remove the pins and plug em back in? also what tool can i use to remove them? thanks
15 minutes ago, wasiq614 said:
any idea where i can buy one?
For de-pinning tools Mainframe customs has them, I would suggest to go for clip in ones if you don't want to be messing around with depinning and repinning:
https://mainframecustom.com/shop/cable-sleeving/tools/molex-extractor/
