Hello!
I'm looking for a new case, so I opened this topic to get suggestions.
Requirements:
  • Good air filtering to prevent dust build up inside the case
  • Has to fit ATX power supply
  • Semi enthusiastic (has the possibility for upgrades and to mount fan and lighting controllers on the outside, for example a couple of 5,25" bays. and space for water cooling)
  • No expansion card limits
  • Otherwise no money or, form factor requirements
https://linustechtips.com/topic/666481-finding-my-ideal-case/
15 minutes ago, Siiskonen said:
Hello!
Requirements:
Since their is no money or form factor requirements maybe look at the
https://linustechtips.com/topic/666481-finding-my-ideal-case/#findComment-8603116
On 9/25/2016 at 8:44 AM, JSD10 said:
There are a lot of options.You could try an s340
Having an S340 I could tell you that there are no 5.25in bays... it does have good expandability, the construction is solid, watercooling in this case will be limited though and the side windows scratches really easy. The NZXT Kraken 140mmx140mmx25mm is what they recommend as it will fit in the case so any other rad. that is the same size would fit as well.
Honestly i would recommend the Cooler master mastercase pro 5 has the best modular system in my opinion. AIO coolers will fit but a Costume loop might be a little more tricky. I built a computer for my brother with this case and i wish it were mine.
https://linustechtips.com/topic/666481-finding-my-ideal-case/#findComment-8612892
Corsair 760T?
EDIT: Sorry never mind, dust
CPU — AMD Ryzen 7800X3D
GPU — AMD RX 7900 XTX - XFX Speedster Merc 310 Black Edition - 24GB GDDR6
Monitor — Acer Predator XB271HU - 2560x1440 165Hz IPS 4ms
CPU Cooler — Noctua NH-D15
Motherboard — Gigabyte B650 GAMING X AX V2
Memory — 32GB G.Skill Flare X5 - 6000mHz CL32
Storage — WD Black - 2TB HDD
        — Seagate SkyHawk - 2TB HDD
        — Samsung 850 EVO - 250GB SSD
        — WD Blue - 500GB M.2 SSD
        — Samsung 990 PRO w/HS - 4TB M.2 SSD
Case — Fractal Design Define R6 TG
PSU — EVGA SuperNOVA G3 - 850W 80+ Gold
Case Fans — 2(120mm) Noctua NF-F12 PWM - exhaust
          — 3(140mm) Noctua NF-A14 PWM - intake
Keyboard — Max Keyboard TKL Blackbird - Cherry MX blue switches - Red Backlighting
Mouse — Logitech G PRO X
Headphones — Sennheiser HD600
Extras — Glorious PC Gaming Race - Mouse Wrist Rest
       — Glorious PC Gaming Race - XXL Extended Mouse Pad - 36" x 18"
       — Max Keyboard Flacon-20 keypad - Cherry MX blue switches
https://linustechtips.com/topic/666481-finding-my-ideal-case/#findComment-8618014
On 9/25/2016 at 7:40 AM, Siiskonen said:
Hello!
Requirements:
s340 ELITE!!!!
https://linustechtips.com/topic/666481-finding-my-ideal-case/#findComment-8618390
