Hey guys,this is my first post and i have a few questions about the PC parts I chose before buying it,I wanna know if it is compatible and i also wanna know which parts are just not need and what parts are needed.
By the way,Im 15 and also Im from Singapore and this is also my first PC Build.
Case: Corsair Carbide Series SPEC-01 Mid Tower Gaming Case Black
CPU: Intel® Core™ i3-6100 Processor (3M Cache, 3.70 GHz)
Motherboard: MSI B150M Bazooka Plus Motherboard
Ram: Kingston HyperX FURY 8GB Desktop Memory 2133MHz DDR4 CL14 DIMM 1.2V Low Voltage 288-Pin HX421C14FB/8
PSU: Corsair CX Series CX450M 80 PLUS Bronze Semi-Modular ATX Power Supply
GPU: Palit GeForce GTX 1060 Dual 3GB GDDR5 PCI-E Graphics Card
SSD: 160GB SSD INTEL 320 Series 2.5" SATA Internal Solid State Drive
Extra Case Fan:Corsair Air Series AF120 LED Quiet Edition High Airflow Fan
CPU Heatsink: ID-Cooling SE-214X Heatsink
Thermal Paste: niceEshop 30g Thermal Grease Paste Compound Tube
Total Cost:  SGD 1014.83   =   746.58 USD
Budget is SGD 1100
and also I won't be overclocking.
Question:
1)Is the CPU heatsink needed?
2)Is 1 extra case fan enough?
3)Is the PSU strong enough to run my rig
4)Is the SSD good enough?
5)Is an i3 good enough?
6)Is 8gb of ram good enough?
(I did not put in a HDD as I'm  using the one from my old pc)
My aim is to at least run Overwatch,Gta 5 or Battlefield 1 at atleast Medium or High settings
Thanks and if i post something wrongly,please do correct me.
https://linustechtips.com/topic/666352-first-ever-pc-build/
better psu and if you want to play bf1 and gta5 well look at maybe an i5.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601786
Question:
Swap that I3 for an i5 6600k, it will last longer and you can overclock it later if you want.
Also if your going 1060 GTX do the 6gb version for memory. At high-ultra settings on those games 3gb is going to create bottlenecks to affect performance. 8 GB of ram is fine, most games don't use that much and if you can easily add another 8 later. Ram is one of the cheapest things to upgrade. Currently there are only 1-2 games that actually recommend 16 gb of memory.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601788
what's your budget in SGD?
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601790
Im not looking to overclock as Im not that good in that kind of things and also,i would not want to upgrade to an i5 6600k(wish i could) as in my country,it is really overpriced.
But is my i3 not good enough?Is it really weak?and can't i run the games i wanted to at least medium settings?
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601814
1) You should get a better CPU cooler if you can afford it
2) I'll recommend at least 1 in the back and 1 in the front
3) Get a higher quality one if possible
4) Yes, take a look at Samsung SSDs too
5) Good enough for medium settings in most games
6) Yes it's enough
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601827
6) Yes it's enough
Alright,I decided to wait a bit longer and to increase my budget to 1500 SGD,so i upgraded my CPU to Intel Boxed Quad Core I5-6600 3.3GHz Processor,i change my PSU to Superflower Leadex Silver 90+ Full Modular 550W,added 1 extra case fan and also upgraded to CPU Heatsink to ID-Cooling Frostflow 120L CPU AIO.Good enough?
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601849
Try to get a least a Tier 4 PSU on this list
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601857
cpu and mobo:i5 6500 and h110m pro vhl $406
graphics card, ram,ssd,case and psu:zotac gtx 1060 6gbkingston ddr4 2133 16gb valueramsandisk ssd plus 240gbarmageddon microtron t2zcorsair cx450m $609.30*
total: $1015.30
after lazada app HURRYSEP100 $100 promo code($600 minimum).
all prices not bracketed are from pcthemes in sim lim square. do ask around for price quotes and discount.
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601866
Just now, JoKr said:
Tier 4,sorry,I'm not that good at this,could you help me?
http://www.lazada.sg/shop-power-supply-units/
cx450m is tier 3, pretty decent psu. if you cann spend more get the leadex silver but sticking with the cx450m is still a good choice.
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601870
I don't really recommend lazada, look on Carousell, and get the price lists of Bizgram, CyberMind and tradepac
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601883
lazada quite a few of the sellers are the distros themselves, or the retailers in sim lim. very reliable.
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601887
total: $1015.30
So I should just throw off my shopping list on lazada and look somewhere else?
What do you mean by carousell,Individual sellers,2nd hand sellers or dealers?Should i go sim lim?would the price be higher or lower?Can they be trusted?
Or is there any better Website or source i could buy the parts from in Singapore
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601897
get the motherboard and cpu from sim lim, the rest get from lazada. lazada right now got excellent promo code, $100 off for $600 purchases so it'll be cheaper than the stores. the pc component sellers in lazada are usually singapore's main distributors and sim lim's retailers.
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601911
1 minute ago, herman mcpootis said:
get the motherboard and cpu from sim lim, the rest get from lazada. lazada right now got excellent promo code, $100 off for $600 purchases so it'll be cheaper than the stores. the pc component sellers in lazada are usually singapore's distributors and sim lim's retailers.
Alright then,I'll get the motherboard and CPU from Sim Lim.Is the Cpu(Intel Boxed Quad Core I5-6600 3.3GHz Processor) and the motherboard( MSI B150M Bazooka Plus Motherboard ) i listed good enough?and can they be found in Sim lim?and about the PSU,what if i upgrade it to EVGA G2 80+ Gold Full Modular PSU?Is that a tier 4?
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601927
It is weak for current and coming gen games, if your not going to over clock go i5 6600 standard if you can afford it.
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601939
good enough. but get the 6500 instead, 6600 not worth the extra price. supernova G2 is a tier 1 psu, very good. but the superflower leadex gold is cheaper and the same so i recommend that instead.
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601940
Ok so i5 - 6500 and the psu will be the superflower leadex gold 550  watts,is that right?
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601955
That should be more than enough for the 1060 and CPU, but I am not familiar with superflower, they may be an off brand with bad quality and one thing you never want to skimp on is the psu, go corsair or evga or cooler master if you can get any of those, preferably with at least a bronze rating.
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601966
cpu and mobo: i7 6700 and gigabyte b150m-d3h $600
graphics card and case: palit gtx 1070 dual and tecware alpha $524*
ram and ssd: kingston ddr4 2133 8gb valueram(2) and samsung 850 evo 250gb $219*
psu: superflower leadex gold 550w $139
total: $1482
*after lazada app HURRYSEP100 $100 promo code($600 minimum).
**after lazada app HURRYSEP30 $30 promo code($200 minimum).
all prices not linked are from pcthemes.
https://linustechtips.com/topic/666352-first-ever-pc-build/#findComment-8601974
