NEED HELP NOW PLEASE
By
cookiemelon
in Troubleshooting
in Troubleshooting
Solved by Bananasplit_00,
i would think that the cooler pump has diededed and that you need a new cooler, im surpriesd you can even get it running and not getting overheated and shut down without a cooler that works tho, guess that the block and stagnent water is enough to disapate some heat
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
