1 minute ago, Graphty said:
Hey guys, can anybody answer some questions i have. I want to make sure my first build is a success.
If you have questions, type them, that way people don't have to go through the effort of reading your mind.
/s :P
i like linux
https://linustechtips.com/topic/666166-first-build-help/#findComment-8599920
Give us a budget and we will come up with something. Shadow is very good so I would really look into what he suggests when you post your budget
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/666166-first-build-help/#findComment-8599927
Never forget the I/O-shield.
CPU Ryzen 5 1600 @3.8Ghz
RAM G.Skill Aegis 2x8GB DDR4-3000
MoBo ASRock Fatality B350-ITX/ac
Graphics Asus Strix GTX 1060 6GB
Storage AData SP550 120GB + 2 Western Digital 1TB
PSU bequiet! Pure Power 10 CM 500W
Case Phanteks Enthoo Evolv ITX
Monitor AOC G2260VWQ 21.5"
Peripherals Gigabyte Force K85 + Logitech G502 Proteus Spectrum
https://linustechtips.com/topic/666166-first-build-help/#findComment-8600029
yeah we need a budget and a primary use of the system to give you a parts list, unless you know what you want generally speaking just make sure when you build your system has atleast a 80 plus certified or better psu, make sure whatever motherboard you get has good ratings and you check the motherboards revision(typical will show where the audio capacitors are on the motherboard (ex: Rev. 1.0), and read reviews as long as out of 20 buyers only 5 or less are bad and the rest are good(ex: z170-e ASUS has 34 reviews in total on newegg and has 30 good reviews and only 4 bad(only the ones who post DOA are the ones i count as bad) so its really only 2 bad reviews out of the 30, generally speaking its a good board) use this as a base for building you pc, not that specific board but any as long as the reviews meet up to the less then 5 out of 20 guideline i say for mobos, and read if the cpu and ram are supported by the board right from the start, you can do so by looking up the model number of the board and looking on there supported CPU/RAM chart. Hope this helps
https://linustechtips.com/topic/666166-first-build-help/#findComment-8600048
