Need help with google drive
Go to solution Solved by LogicalDrm,
My understanding is that Google Drive doesn't sync other folders on PC. It syncs folders and files which are placed in the root Google Drive folder on PC. So you can't set folders outside Google Drive folders to be synced. You must move those files and folders into Google Drive folder to be synced. Did this make any sense? Tested on Win7.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Thanks for the help, it did make sense and thanks you for testing it.
