What fan headers are temperature controlled?
Go to solution Solved by WoodenMarker,
They all are.
Hello!
I want my PC fans to be controlled by the temps of my pc and, Im planning to get an NZXT fan hub, and connecting it to one of my fan headers,
(I read a review that someone attatched the master header, in order to allow ALL the fans to change speed relative to temps)
Im guessing that it would be the cpu fan header, but if it helps; i have a Gigabyte Z97P-D3.
Any and all help is appreciated.
https://linustechtips.com/topic/666013-what-fan-headers-are-temperature-controlled/
10 hours ago, JerichoN said:
Hello!
You can setup each fan header to vary with temp probes around the motherboard.
They all are.
