GT 420 is garbage from 2009. What exactly do you expect? It couldn't play games in 2009, it still can't play games in 2016
https://linustechtips.com/topic/665929-gpu-problem/#findComment-8597823
Did the tech guy recommend the 420 to you? If he did hes an ass.
The 420 is outdated horribly, and isnt really meant to play games. Id recommend returning it and getting something else, if you tell me the budget for a new gpu i can help you find a better replacement.
https://linustechtips.com/topic/665929-gpu-problem/#findComment-8597824
Specs for rest of your system? :D
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/665929-gpu-problem/#findComment-8597827
:D thx he isnt realy a tech guy after all
https://linustechtips.com/topic/665929-gpu-problem/#findComment-8597836
yeah i noticed that. dat noob guy thinks that it is still good, that it would run games. i knew this gpu was shit but i didnt knew that it was that shit.
Thx.
https://linustechtips.com/topic/665929-gpu-problem/#findComment-8597850
Thx.
What CPU and PSU do you have?
https://linustechtips.com/topic/665929-gpu-problem/#findComment-8597856
1 minute ago, techp said:
i3 2120 dont know about PSU . pc is shit not even worth upgrading.
If you can, get a SeaSonic S12II 520W and a 750 TI - the 520W S12II can be re-used if you upgrade the PC and the 750 Ti will deliver solid performance - about 150fps in CS:GO.
https://linustechtips.com/topic/665929-gpu-problem/#findComment-8597883
