Fan spin up issues.
Solved by WoodenMarker,
On 9/25/2016 at 4:15 AM, Toxiic said:Both are 4pin PWM
You should not be using the LNA if you're controlling the speed from the motherboard.
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3 -
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0
play_circle_filled
Latest From ShortCircuit:
