9 minutes ago, tt2468 said:
Cool, but is it really necessary?
Nope. If you have a 4GB+ text file you need to edit, I think you have other problems.
What are the chances the plugins will work as is?
https://linustechtips.com/topic/665364-64bit-notepad/#findComment-8592440
If you need to edit a 4GB+ text file, you can just use HxD to do it.
Ensure a job for life: https://github.com/Droogans/unmaintainable-code
Actual comment I found in legacy code: // WARNING! SQL injection here!
https://linustechtips.com/topic/665364-64bit-notepad/#findComment-8592450
There are a few other programs much like this HTML editor that are based on  x86 architecture. Built around the Windows XP platform and prior, another is a database one called SAP, which still seem to be working / running fine on a Windows 8.1 machine. But you could hardly see someone buying institution licenses at $4,000 per user and not owning a WX machine!.
This update may be to enable them to work in the Windows 10 environment moving away from the "16-bit applications" they once were!
Link:
http://www.howtogeek.com/219782/is-windows-10-backwards-compatible-with-your-existing-software/
Those who deny freedom to others deserve it not for themselves (Abraham Lincoln,1808-1865; 16th US president).
https://linustechtips.com/topic/665364-64bit-notepad/#findComment-8592561
