Ok so i initially thought this was an issue with Haswell, but it's not, i got a PSU that works on a P4 mobo but anything above that it doesn't want to power it on. 478 it has no issue, 775 or above it doesn't wanna work. Does anyone have a clue as to why, on the 1155 board the small LED was glowing a bit green, but nothing happened, when i plugged in another PSU the light was brighter, if that helps.
Any ideas help :)
https://linustechtips.com/topic/665067-psu-issue/
Any ideas help :)
Probably the PSU itself is dying
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/665067-psu-issue/#findComment-8589127
2 minutes ago, CAPCOM UK said:
Need to know a lot more about the PSU.
Make and model? 12 volt amperage ratings?
2 minutes ago, Electronics Wizardy said:
What PSU?
Its probably a cheap one that doesn't like the extra power draw.
850426845_1_644x461_fonte-alimentao-lc-p
Yes it's a cheap one, i got it with a P4 system, didn't expect much from it since it LC Power, but i hoped atleast that it would be enough for the 775 system.
https://linustechtips.com/topic/665067-psu-issue/#findComment-8589140
32 minutes ago, CAPCOM UK said:
It is perhaps quite decent for an old supply but you should definitely replace it, it's innards are not designed for long life.
Nvm, i tested something and it's strange. If i flip the back switch and try to power on it doesn't, but if i flip the back switch and wait a bit, it'll then power on when i press the power button, might be the capacitors at fault?
https://linustechtips.com/topic/665067-psu-issue/#findComment-8589327
Yeah caps sound close to blowing or are just failing to hold current.
Replace it ASAP.
Pentium IV @ 4.4ghz , 8GB DDR2, R9 380 4GB, 2560x1440p monitor.
https://linustechtips.com/topic/665067-psu-issue/#findComment-8589330
