HBM stands for High Bandwidth Memory and handles things a bit differently. With GDDR5 and GDDR5X, the vRAM is mounted onto the board directly around the GPU with the memory controllers then connected to the chips. HBM however has everything integrated into the GPU package, including the memory chips.
The stack-up for HBM is as follows:
Memory chips and GPU(top)
Interposer(middle. It acts as the connection between the GPU and memory. With the memory chips and GPU closer together, bandwidth is increased by a lot.
Package.
The great advantage to HBM is that it saves a lot of space. Whereas each chip on GDDR tech is discrete and separate, HBM chips can be stacked on top of one another. Just to give you an idea of how much smaller HBM is, reference the image below.
And here is the stack-up of HBM imaged:
And AMD's Fury X die using HBM:
Edited by Godlygamer23
https://linustechtips.com/topic/664741-difference-between-these/#findComment-8585485
Just now, dexxterlab97 said:
gddr5x because 1080 is using it.
Package.
  Hide contents
Not signed in
  Reveal hidden contents
Smaller is better!
Strike the shepherd and the sheep will scatter.
https://linustechtips.com/topic/664741-difference-between-these/#findComment-8585493
