I no this has been done to death in the past but I want to no how it stands as of today
is it beneficial to have a i7 over i5 for gaming
144hz
1440p
sli 980ti
16gb ram
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/664270-gaming-i5-vs-i7-same-generation/
144hz
1440p
sli 980ti
16gb ram
High refresh gaming? SLI? Yeah, you need as good of a CPU as you can possibly get. Get the i7 if you can.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Talking of bottleneck with a 6600k is funny. Sometimes i wonder what people think a bottleneck is.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
Well u want ur gpu to bottleneck when gaming so if the cpu stops ur gpu from being pegged at 99 percent usage u have a bottleneck
also (1600)
I know what a bottleneck is. Saying the 6600k would bottleneck a 1060 is a fairytale. Alot of mystic bottlenecks like this haunt LTT these Days.
Depend if the game will utilize that extra threads, if the game only use 4 cores then a higher clock 6600k is better than a lower clock 6700k.
I find it ridiculous how people think i7s don't yield any further performance gains over i5s. If you have the money, there's no harm in spending the extra to get the extra performance and stability the i7 offers.
For 144Hz gaming, you'll definitely benefit from a i7. Hell, even a i7 6700K bottlenecks two GTX 980Tis at 1440p in games such as The Witcher 3 and Fallout 4.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
I agree but iv never had cpu bottleneck in witcher 3 my 980tis stay at 99 percent usage just mediocre scaling in that game
also (1600)
Is that with ultra settings and Hairworks on?
Ye man hair works at aa2 tho because I can't see the difference but still hair works on
also (1600)
Alright. I'll look deeper into it because these results contradict Techspot's own benchmarks where a i7 6700K didn't bottleneck a single GTX 980Ti while it did when there were two.
You may notice a difference when....
1. Streaming
2. Background processes (i.e. Chrome, recording software, etc...)
3. Higher minimum FPS
That's a cut and dry answer.... if I was running SLI I sure wouldn't skimp $80-100 to not double up on my logical threads.
They running stock or oc ? Cause I'm at 4.8 on all cores now and cache at 4.6
also (1600)
Overclocked to 4.5GHz.
my i5 6600K + 980 ti build outperforms most i7 + 980 ti on 3Dmark
what I mean :
higher graphic score (mine 21400)
lower physics score (of course, less cores, still 11K)
higher combined score (9900)
where is my bottleneck ? 80-120 fps @2K on all games (even 4K on older ones) except most demending ones (60 on witcher 3)
what I mean :
What are your overclockis
also (1600)
22 minutes ago, belfouf said:
i5 6600K @4,5 @1,275v (100x45)
msi gaming 980ti @+150 core +500 memory +87mv (watercooled)
Specifically if bottleneck in gta v and the witcher 3 and fallout 4 as it been proven many times more corse make a difference
and my original question wasn't the top i5 vs the lowest i7
also (1600)
I honestly have no idea how some of you guys are seeing bottlenecks in the Witcher 3 and GTA V.  I'm rocking a 3570K OC'd to 4.2Ghz and have yet to see my CPU maxed in TW3 in any region.  The only time I see GTA V slow down is when driving through offroad areas with the grass quality setting at ultra.
CPU -AMD R5 2600X @ 4.15 GHz / RAM - 2x8Gb GSkill Ripjaws 3000 MHz/ MB- Asus Crosshair VII Hero X470/  GPU- MSI Gaming X GTX 1080/ CPU Cooler - Be Quiet! Dark Rock 3/ PSU - Seasonic G-series 550W/ Case - NZXT H440 (Black/Red)/ SSD - Crucial MX300 500GB/ Storage - WD Caviar Blue 1TB/ Keyboard - Corsair Vengeance K70 w/ Red switches/ Mouse - Logitech g900/ Display - 27" Benq GW2765 1440p display/ Audio - Sennheiser HD 558 and Logitech z323 speakers
If you uncap the framerate, use a video card capable of reaching 80+ FPS, and run around in Novigrad staring at GPU/CPU usage meters, you can usually find that once over 70 FPS or so, the i7 adds another 0–10 FPS on top of a same-gen, same clock speed i5. Similar results can be found in GTA V.
However, while that's "a difference" in favor of the i7 (I've seen similar differences from using very high-speed DDR4, fyi), I'm not sure it's a relevant one to most people. For those with 60 Hz displays, the i5 will hit 60 and stay at 60 without question. For those with 144 Hz displays, neither CPU (and probably no CPU available) is getting there in those games. In games where the i7 can reach 144 FPS, the i5 is still usually just a few FPS behind. So for $100 difference, I'm still not convinced it's the best use of your budget in a gaming system.
