Headset selection problem
So yeah, I'm kinda stuck in a corner here. My current headset keeps, like, I dunno, "hurting" my ears, like it cups them and squeeze them too hard and it hurts when I remove them? Or when I play for like more then an hour straight. I also wear glasses, which could be part of the problem. I tried playing with a hat or whatever, it's hot in here though, hehe. So there you go, since I obviously can't go to just any store and try a few headset on, I need some feedback or suggestions from you guys. Pls.
Anyways, thanks
https://linustechtips.com/topic/664088-headset-selection-problem/
What ones do you have now so we have a general idea of what to avoid
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
Hum...They are turtle beach from like, 2011-12, shitty 60 bucks a piece, from back when I gamed on Xbox 360. I believe earforce x12, some shit like that.
Explains it, max budget and assuming you need a MIC of some form?
yeah I know 60$ = shit value and major hurts, at the time I was 15 though so it worked fine for my standards...back then.
At this point I know I want a wired headset, so yeah of course mic is included, that's the difference between headset vs headphones right?
Budget I'd say something like $200 CAN? That's good value right?
At this point I know I want a wired headset, so yeah of course mic is included right, that's the difference of headset vs headphones right?
I'll be home in a bit, at that price you may be better off with a quality pair of headphones and a separate MIC.
Oh shit never though about that. I'll continue research on this side though, not gonna lie, but I'd still like feedback/ideas
Something like the Sennheiser 380 Pros may be nice for you. I have the 280 Pros and with a little 2 year old sister they do block out a good portion of the sound, especially once you start playing something like music.
That'll leave CND $50 for a microphone which should be plenty, maybe something like a BM-800 or NW-800 or look into a Dynamic Cardioid microphone ( If there is a ton of background noise in your house such as people talking ect ) a dynamic cardioid mic should block out most of it along as it isn't facing in the general direction of where the sound is coming from.
I would imagine that if the mic is a standalone one it's going to need some extra software to run right?
Not all the time, most mics are plug and play and usually say if they aren't.
