RGB lights suggestions
Go to solution Solved by CableMod,
6 hours ago, EQuiPeX said:
Hello, I just kind of finished my watercooled pc build and want to know which rgb remote controlled led strips are most popular and reliable(also cheap). And please add links for europe :)
Thanks!
check this:
You can get them here: https://eustore.cablemod.com/products/?filter_color=rgb
If you like music check this out:
http://www.audectra.com/
The audio reciver is usb and not a microphone making the response times lagless also works with headphones on,
there is a static mode too but the other settings are audio related so no pulse or w/e.
here was a test: (sorry for the low quality it was taken on my phone >.<)
https://linustechtips.com/topic/662346-rgb-lights-suggestions/#findComment-8559950
the basic led kit i brought to make the audcetra was this: https://www.amazon.co.uk/SINOU-Waterproof-Flexible-Controller-Decorative/dp/B01JUGSV9G/ref=sr_1_2?s=kitchen&ie=UTF8&qid=1474140095&sr=1-2&keywords=SINOU
the lighting is good and was packaged well
https://linustechtips.com/topic/662346-rgb-lights-suggestions/#findComment-8559969
Thanks!
If you want a premade ready to go solution Cable Mod makes some quite nice LED kits, some other also such as Addoncustoms and Modguru also make similar kits.
https://linustechtips.com/topic/662346-rgb-lights-suggestions/#findComment-8561526
Thanks!
check this:
https://linustechtips.com/topic/662346-rgb-lights-suggestions/#findComment-8561798
